Transmission fluid change
  • scott resick
    • Jan 2012
    • 532
    • Pittsburgh
    • 2006 196 Limited
    I did a quick search on this but nothing found. Anyone have a good how to on draining the tranny? '06 196 PCM RATO 1:260
    thanks
  • Quinner
    • 2246
    • Correct Crafts
    Assuming you meant you have a PCM 1:23 trans. You will need a good suction pump, like a mityvac or similar, You can usually get about 2 quarts out with the pump, check fluid level before you start, if full add what you took out, check after you run it, a little over full is better then low. DO NOT USE SYNTHETIC FLUID. You should really be changing that fluid every season or 100 hrs.
    • scott resick
      • Jan 2012
      • 532
      • Pittsburgh
      • 2006 196 Limited
      thank you Quinner. The book says it should be a 1:23 ratio but the tag on the unit is stamped 1:260? It says to use DEXRON III.
      • Quinner
        • 2246
        • Correct Crafts
        Scott most of what you will find on the shelves will be labeled Dex/Merc which is compatible as Dexron III, as mentioned use conventional not synthetic.
        • swc5150
          • 2240
          • Eau Claire, WI
          • MasterCraft Prostar
          Hey Chris, how come no synth out of curiosity?
          '08 196LE (previous)
          '07 196LE (previous)
          2 - '06 196SE's (previous)
          • Quinner
            • 2246
            • Correct Crafts
            That is what Erik who was the former owner of the Trans Shop Fantastic Finish Marine always said, he described it as too slippery.
            • Whitetail15
              • Apr 2010
              • 603
              • 2016 G23 H6
              scott, don't stick a plastic hose in there. It could get stuck and break off. Make sure you have a skinny copper hose to put in the tranny. I almost had that happen to me.
              2016 G23
              • scott resick
                • Jan 2012
                • 532
                • Pittsburgh
                • 2006 196 Limited
                thanks whitetail15!!! maybe Ill see you this year huh?
                • 92 natique
                  • May 2017
                  • 1
                  • Sandy Utah
                  • 92 ski natique
                  I have a 92 natique which uses 20 weight motor oil. I've used some up that I've had in stock in that I'm trying to find some. any ideas. Also can it be none detergent
                  • Whitetail15
                    • Apr 2010
                    • 603
                    • 2016 G23 H6
                    i need to make a trip up your way. soon
                    2016 G23
                    • Aebert2668
                      • Oct 2014
                      • 49
                      • Atlanta
                      • 2006 SAN 220 2006 18' Hewes Redfisher 1979 16' Duracraft
                      2 foot long section of 1/4 inch copper tubing at Home Depot. 1/4 plastic tube, 3 foot long, unless your hand vac is 1/4 tubing. Move the copper tube around some while vacuuming. When topping of with new fluid remember to engage forward and reverse gear, then recheck the level and add fluid. Don't forget to replace dipstick before engaging gear, yeah I was rushing, don't ask
