Hydro gate problems?
  • tftackett01
    • Jun 2016
    • 16
    • Pontotoc, MS
    • 2008 SV211 Team Edition
    I have a 2008 SV211TE, I think I have an issue with the hydro gate. When it is disengaed, or forward in the sloloam position, for cruising or pulling the kids on the tube, it will not stay in that position. It jumps back into the wake position, especially when slowing. Is this normal, and if not, how could I adjust tension on the cable. I'm assuming it's only a mechanical cable. Any help? And thanks in advance.
    Sent from my SAMSUNG-SM-G935A using Tapatalk
  • tftackett01
    • Jun 2016
    • 16
    • Pontotoc, MS
    Can't find anything else online about the gate's operation. And there's not a Nautique dealer within 150 miles
    • traves_peterson
      • Aug 2015
      • 15
      • Ramsey, MN
      It's not normal. My 2008 SV211 stays exactly where I put it no matter what. There must be a way to tighten it up. Not by my boat or I'd look.
      • homer12
        • Feb 2016
        • 584
        • Indianapolis, IN
        • 2004 SV211 TE
        I believe when it is in the forward "slalom" mode it is engaged and not disengaged. In other words, in slalom mode is when it is dropped below the bottom of the hull running surface, so something is probably not tight enough to keep it there. Water force is probably pushing it back to wake board position. Can you tighten the screws that the plate slide on at the transom slightly?
        • tftackett01
          • Jun 2016
          • 16
          • Pontotoc, MS
          Thanks guys. The boat has just over 1100 hours so screws may have worked themselves loose. I'll give that a shot when I get home tonight to see if that will be the remedy. Thank you guys again
          • tftackett01
            • Jun 2016
            • 16
            • Pontotoc, MS
            Update!!!! The small ears that attach the hydro gate to the plate that slides up and down have broken. No big issue to fix, just hoping that the plate is stainless steel and not aluminum (stainless sheet metal is so much easier to weld). Just have to take it off and carry it to work one morning.
            Thank you guys for all the input.
            • homer12
              • Feb 2016
              • 584
              • Indianapolis, IN
              • 2004 SV211 TE
              Can you post pics when doing it? I'm curious if I ever run into a similar issue. thanks!
              • tftackett01
                • Jun 2016
                • 16
                • Pontotoc, MS
                Sorry I had already repaired the part the next day. I tig welded the small ears back onto the plate, along with two cracks that ran horizontally across the plate. Simple fix, easy to remove and reinstall. The welding is a little tricky of you're not used to welding thin sheet metal.
