Help identify which OJ prop I have
  • 99SAN
    • Oct 2010
    • 172
    • Roll Tide
    I removed my prop and i cant find any information on it besides being a 14x18.
    It's stamped behind the nut OJ 14 18P CUP 1 1/8. Here are some pictures of the numbers on the blades.
  • 99SAN
    • Oct 2010
    • 172
    • Roll Tide
    Also, I have a older xpc dripless shaft seal and need the sealing rings. Where can I buy them?
    Sent from my SM-G930V using PLT Nautique mobile app
    • 99SAN
      • Oct 2010
      • 172
      • Roll Tide
      Anyone?
      • xlair
        • 694
        • Wisconsin
        You basically identified the prop correctly. 14x18" 1 1/8" RH 4 blade OJ propeller. There are better props out there, depending on what you are doing.
        Is this what you need for the shaft ?
        http://www.shaftseal.com/en/categories/300000116
        2001 Pro Air Nautique
        • 99SAN
          • Oct 2010
          • 172
          • Roll Tide
          • 99SAN
            • Oct 2010
            • 172
            • Roll Tide
            Oh ok, i was thinking there was a number associated with the prop like acme. What is a better prop for better fuel mileage and wakeboarding/surfing? I need the 2 piece seal inside the aluminum housing. Maybe gortex?
            • xlair
              • 694
              • Wisconsin
              Give acme a call about props. They will give you good advice.
              • Evening Shade
                • Apr 2015
                • 1295
                You can also call OJ and they can give good advice as well. Eric Johnson at OJ is very knowledgeable about inboard props.
