2002 Shredded Impeller
  • rcazwillis
    • Feb 2014
    • 117
    • Fort Worth, TX
    • 2002 SANTE
    Finding all those pieces is near impossible. I took off every hose, back flushed all the components down flow from the pump.
    The rubber is soft, not dried out. Obviously stuck to the walls of the pump. When winterizing, should we just pull the impeller as part of the process?
    Sent from my SM-G930V using Tapatalk
  • Tom_H
    • Jan 2014
    • 244
    • Minnesota
    You could. Some do, and store in a ziploc for the winter. I just prefer to put a new one in each spring as part of getting the boat ready to use. It's so much easier to change a $30 part in the spring each year than to end up shredding one and having to chase down all the pieces. Cheap peace of mind for me. The old one is always in good shape, and I just toss in in a ziploc and keep in the boat as a spare that I don't ever expect to need.
    • charlesml3
      • Jan 2008
      • 2454
      • Lake Gaston, NC
      • 2022 G23
      Agreed. New impeller every spring no matter how many hours we put on the old one. It's a simple DIY job.
      -Charles
      • Nautiquehunter
        • Jun 2008
        • 2080
        When you buy a new impeller make sure its a PCM impeller lots of horror stories about aftermarket impellers.
