2014 G23 NSS not engaging
  • MJB
    • Jun 2006
    • 229
    • Jacksonville, Florida
    • 2014 G23 Coastal Previous Boat: 2011 Team 230
    Has anyone had issues with the NSS not engaging on a 2014 G23?
    Surf is on. Speed control is on but wave doesn't come up and is completely white water.
    Boat is significantly weighted when this was happening. Stock plus 700 in each compartment and 600 in bow plus with 7 people.
    Will NSS not work when he boat is "overweighted"
  • nyryan2001
    • Mar 2013
    • 1993
    • Lake Anna
    Do you have BOTH your surf and speed control on?
    take pics of both and post them both highlighted. Set your speed to 11.6
    2019 G23 450
    2014 G23 550
    2013 G23 450
    2011 Malibu Wakesetter 247
    2007 Yamaha AR210
    • MJB
      • Jun 2006
      • 229
      Yes. Both surf and speed are on 100 percent sure
      • trip33
        • Nov 2010
        • 248
        • Odessa, FL
        That has happened to me a couple of times. I just put the boat back in neutral and then throttled back up and everything was fine. Happened maybe 2 times in 2 years so not anything I was too concerned about. I figured it was like PP not engaging while wakeboarding. That happened on my old 211 with about the same frequency. Same fix. Sorry I don't know the reason but you ate not the only one.
        • all2matt
          • Jun 2015
          • 77
          • bismarck, nd
          • '14 G23 450 Previous: 10 tige Z1 & 02 tige 20i
          Mine does it if I switch sides while in nuetral. I shut the boat off and turn it back then switch sides once I'm popping the rider up.
          • cedarcreek216
            • Oct 2009
            • 1009
            • Dallas, TX
            • 2018 210 2013 210 2009 216V
            Just had my 13 210 in for the same thing, the actuated went out. Seems to be a fairly simple fix and they covered mine under warranty.
            • Btravelin84
              • Jun 2016
              • 29
              • Dallas Fort Worth
              On my 14 g23, this has happened several times. I found the issue to be when you don't give it full throttle and let the speed control take over. Basically if you halfway the throttle up to speed and don't go full throttle it won't kick in all the ncrs and nss. Just what I've noticed- same on wakeboard setting
              Ride or die kids
              • markj
                • 1194
                • NorCal
                [QUOTE=Btravelin84;n522879]On my 14 g23, this has happened several times. I found the issue to be when you don't give it full throttle and let the speed control take over. Basically if you halfway the throttle up to speed and don't go full throttle it won't kick in all the ncrs and nss. Just what I've noticed- same on wakeboard setting
                Yep. Same here on my 230.
                • lucky7t
                  • Mar 2011
                  • 1306
                  • Oklahoma
                  • 2015 SANTE
                  Never heard of overweight being an issue . Try restarting everything . Turn batteries off let it sit for a few minutes then turn back on and restart . Go to your linc and make sure nss is on
                  Current Correct Craft Boat
                  Correct Craft Boats Owned
                  • DaveSA
                    • Sep 2014
                    • 4
                    • San Antonio TX
                    • 2013 G23
                    Did you ever get it fixed? my 2013 G23 is doing the same thing?
