2016 230
Running port ballast drain when I received a circuit fault for the port ballast. I was able to reset the fault and run the pump, although it still lists an error on the pump sender.
Anyone encounter this issue or have an idea what this is about?
My dealer is 2 hours away and I'm trying to decide if I need to tow it up at the end of the weekend. Thanks.
