hi there. I just got a code 2139 FPP1 lower than IVS. Dealer wont help for 2 weeks. Im in Ontario Canada thats half our summer. I think its TCP. my friend the mechanic thinks bad ground at battery. Any help. Manual says there are FPP! and FPP2 and boat will stick at idle if both go out. Boat is out of warranty Is there a GM replacement part or just from PCM. Hope you can help Thanks
Hey fellow Ontarian, did you have any luck solving this error? I'm getting same code on the 2011 Sport 200 and with the same dealer I'm looking at the same delays!
Pride wouldn't venture a guess over the phone. Told me to park boat for 3 weeks. The warning comes on every half hour. Resets after battery switch turns off My own local mechanic says it's bad ground or bad throttle position control I ordered a new one from nautiques parts just in case. They are out of stock so must be a known problem. My mechanic says that it won't stick in idle until fpp1 and fpp2 both go down.
I suspect it's your TCP too. I have a 2008 230 with a ZR6 engine and the same thing was happening to me last year. I took it to the dealer and ask them to read off the codes and I would do the research. Here is my original post:
https://www.planetnautique.com/vb5/f...140-08-san-230
I knew something was up when I called my dealer and they said they had qty. 2 of these parts in stock. $190 at the dealer - $160 online.
It's super easy to change out and it solved the problem.
Good luck!
