G25 Rear Ice Chest
  • Mesajeeper
    • Feb 2012
    • 12
    • Arizona
    G25 Rear Ice Chest
    The rear ice chest in our 2014 G25 simply fell out! It appears that it was just glued in place. The dealer says it simply needs to be glued back in with some sort of epoxy. Can anyone advice on what epoxy would be best? Is this a common occurance?
  • Byeai
    • Apr 2017
    • 45
    • Orlando
    They are put in with plexus no it is not common lol
    Sent from my SAMSUNG-SM-G925A using Tapatalk
    • Mesajeeper
      • Feb 2012
      • 12
      • Arizona
      Thanks for the quick reply. What is "plexus"?
      • Byeai
        • Apr 2017
        • 45
        • Orlando
        It is a 2 part epoxy that we use when we assemble the boat ill try and finds a link
        • Byeai
          • Apr 2017
          • 45
          • Orlando
          Only bad thing is most times you need a cartridge gun to use it unless you find the parts separate just Google plexus epoxy
          • Mesajeeper
            • Feb 2012
            • 12
            • Arizona
            Thanks for the info. The local dealer recommended 3M 5200. I think I will give this a try since I can buy it locally. Anyone disagree with this approach?
            • Byeai
              • Apr 2017
              • 45
              • Orlando
              5200 is great stuff also but make sure you clean the surfaces really well and make sure you hold the chest up until it drys which is "24" hours but should hold itself after a few hours I'd get the fast curing 5200
              • rossrips7
                • Feb 2010
                • 233
                Ditto on the fast cure 5200. (Red tube). The blue tube supposedly takes 7 days to cure.
                • tsatrooper
                  • Apr 2017
                  • 17
                  • Ohio
                  • G25CE 38fountain 02san 96sport
                  When I was messing with my NSS problem I noticed mine had fallen out also. I'm going to 5200 it.
                  • nohlan_4
                    • Jan 2016
                    • 413
                    • Canada
                    • 2013 G23 450
                    I'm having trouble thinking how this would fall?
