2002 stern navigation light
  • wakehead
    • Dec 2009
    • 240
    I realized my stern light that is on a pole that you need to pur into the connecting slot when dark out is not working. There seems to be 3 connections that occur. ON the light pole there is nothing sticking out for a connection to occur, but then I notice that inside the housing located behind the back seat that you flip up to plug the light into there was also nothing sticking out as prongs to allow for a connection. CAN someone tell me what its supposed to look like inside that housing. I am not sure if a piece is missing or what.
    Thanks CC fans
    210 SANTE
  • charlesml3
    • Jan 2008
    • 2455
    • Lake Gaston, NC
    • 2022 G23
    There should be prongs sticking up inside the fitting on the stern of the boat. Most likely you need to take that entire fitting out and replace it.
    -Charles
    • wakehead
      • Dec 2009
      • 240
      Yes I don't see prongs. I am guessing those got broken off
      210 SANTE
