95 gt40 second stage high pressure fuel pump unavailable - what are my options?
  • AlexS
    • Jun 2017
    • 2
    • Huntsville, Al
    • 95. Skinautique
    I am having starting problems with my 1995 Ski Nautique GT40 ski boat. When checking out possibilities I found a small amount of fuel leaking at the output end of the high pressure fuel pump. The threads appear stripped in the unit. It turns out that the part is no longer available. I believe the part number for PCM is ra080023. I saw skid makes a replacement fuel system for $800 plus dollars. I was wondering if anyone has dealt with this and found a source for the pump or a cheaper solution.
  • xlair
    • 694
    • Wisconsin
    Your best bet is probably to convert it to the fuel control cell. Expensive but that's the right system
    2001 Pro Air Nautique
    • AlexS
      • Jun 2017
      • 2
      • Huntsville, Al
      • 95. Skinautique
      Thanks for your advice. I have loved the boat but starting to wonder about it because of obsolete parts. I had another problem and was worried about the ECU.
      The problem was something else but I found out these are no longer available either. So I feel as though everything I do on it is wasted if the ecu goes out. The boat will be inoperable.
