2015 SAN 210 Engine Performance
  • Flyindutchman
    • Sep 2016
    • 213
    • North Bay, Ontario
    • 2015 Super Air Nautique 210
    So I've only been out cruising and surfing at this point but I do have a concern that I noticed when I tried to make a quick run back to the cottage for a bathroom break with the ballast tanks still full (Factory Pro Ballast - 1750lbs). My 2015 SAN 210 has the PCM343 engine and I had to go to WOT and also engage the hydro gate to get onto plane with 3 other people in the boat. Does that sound like normal performance for this boat?
  • XBIGPUN66
    • Oct 2012
    • 456
    • WI
    Need a lower prop. We had the same problem. Got a 1617 and it is way better. Better speed control while surfing also.
    Sent from my SAMSUNG-SM-G930A using Tapatalk
    Ian S
    2014 SANTE. NSS. Pro balllast. Boatmate trailer
    2004 SANTE. 4000 lb ballast, 2013 graphics (prev). Ramlin trailer
    2009 Moomba Outback (prev). Boatmate trailer
    • Flyindutchman
      • Sep 2016
      • 213
      That is really good to hear actually. I was just worried something might be wrong with the engine but if that is normal I am fine with it. Thank you for the response.
      • nyryan2001
        • Mar 2013
        • 1993
        • Lake Anna
        14x12 prop.
        2019 G23 450
        2014 G23 550
        2013 G23 450
        2011 Malibu Wakesetter 247
        2007 Yamaha AR210
        • Phil8uga
          • Oct 2016
          • 383
          • Georgia
          What is WOT?
          • charlesml3
            • Jan 2008
            • 2456
            • Lake Gaston, NC
            • 2022 G23
            Originally posted by Phil8uga View Post
            What is WOT?
            Wide Open Throttle
            • Phil8uga
              • Oct 2016
              • 383
              • Georgia
              Thanks.
              • Flyindutchman
                • Sep 2016
                • 213
                Wide Open Throttle
                Yeah...but I meant it as 'Wicked Osome Turbo'...if you can handle misspelling awesome that crudely...lol
                • Flyindutchman
                  • Sep 2016
                  • 213
                  14x12 prop.
                  Thank NYRyan - I have to admit that I read threads about props and get lost with some people referencing only the ACME XXXX and others referencing diameter and pitch but nothing else. For example: what is the ACME 1617? Is that a 14x12?
                  Thanks for any feedback.
                  • jondavis08
                    • May 2016
                    • 369
                    • Battle Creek, MI
                    • 2014 SANTE 210 2003 SANTE 210-Sold
                    I have a 2014 210, the acme 1617 has been a great addition!
                    • nyryan2001
                      • Mar 2013
                      • 1993
                      • Lake Anna
                      Pay attention to diameter, pitch and cup.
                      When I say 14x12, i Don't care if it's an Acme or an OJ.
                      google acme 1617 you'll see it's a 14x13.75.
                      great prop for mild wakeboarding, skiing and cruising. This prop will save fuel for most activities.
                      not a great prop for carrying the heaviest weights. You guys in these 350 21ft boats need 14x12s if you want fastest holeshot with the heaviest weights.
                      cup. .105 is more agressive than .150. I think it's so agressive it's borderline inefficient for the weight/launch gains you get.
                      14x12 .150 cup is what you guys need.
                      14x12 .105 cup would be a massive improvement over these 14x14s, 13x16+ props.
                      2019 G23 450
                      2014 G23 550
                      2013 G23 450
                      2007 Yamaha AR210
                      • prowakeskater
                        • Aug 2016
                        • 58
                        • florida
                        • 03 SANTE
                        so how would that 14x13.75 compare to a 13.5x14.25?
