2011 210 SANTE tower issue
  • Free48
    • Jun 2014
    • 119
    • Montana
    • 2019 SANTE 230 2017 SANTE 210 2011 SANTE 210 1991 454 BFN 1989 SN 2001 Ski Ray inboa
    Is there a service manual that provides detail on how to properly rig the tower cam locks? One of our locks will not catch properly. The last Nautique dealer I spoke to suggested I purchase an aftermarket tower (not kidding). Any help would be appreciated.
  • Outdoorjp
    • Jul 2016
    • 178
    • Carlsbad
    • 2011 SAN team 210
    I'll write a detailed response latter today. Pretty easy, I just tore mine down for repaint.
    and adjusted mine from poor factory setting.
    • Outdoorjp
      • Jul 2016
      • 178
      • Carlsbad
      • 2011 SAN team 210
      With tower up and lever latched see how much play tower has. (This is the amount of shims you will remove later)
      Take the outside cover plate off. With tower up take out bolt that holds saftey cable.
      lower tower remove clip holding aluminum latch handle behind outer cover.
      pull Handle out. 2 bolts hold latch assembly down inside. Takes long Torx bits.(harbor freight sells long bits).
      There are shims under this latch. Remove the needed thickness of shims and reassemble.
      • Free48
        • Jun 2014
        • 119
        • Montana
        Thanks Outdoorjp! Doesn't sound too bad. Are there diagrams or pictures available? Or possibly when I remove the cover it will be self explanatory?...
        • Outdoorjp
          • Jul 2016
          • 178
          • Carlsbad
          • 2011 SAN team 210
          The aluminum handle is basically kept in by a c-clip with a small straight set screw. But to see/get to it you have to take off outside tower cover.
          no diagrams that I know of.
          After I adjusted my tower by removing most of the shims my latch now locks in my tower super tight and I don't even need the saftey blocks.
          • Free48
            • Jun 2014
            • 119
            • Montana
            Worked perfectly! Thanks Outdoorjp.
            Troubling that the dealer I visited suggested that I replace it with aftermarket...
            • rsess
              • Nov 2010
              • 48
              • toronto
              • 2017 G23
              I have 2012 with the removable safety bolts How important are these bolts to use
              • Free48
                • Jun 2014
                • 119
                • Montana
                I've been using the safety bolts mainly because of this cam lock issue however if I'm able to rig the cams properly I intend to forego the bolts. I believe the bolts were added to eliminate risk to Nautique.
