2001 Air Nautique 210 Horn Location
  • psuchaz
    • Jun 2017
    • 4
    • NV
    • 2001 Super Air Nautique TE GT-40
    HI, Could someone please describe where the horn is located on a 2001 SAN 210. I have searched and have only found the description for a closed bow boat. Horn stopped working over the winter and based upon the searches it sounds like tapping it or adjusting the screw maybe a quick solution. Thank you ahead of the for any help.
  • wakejunky
    • 679
    • Ca
    • 2003 SAN
    I should be under the observer's seat (port side) and almost straight up as you peer in. If you look from the outside you should see a plastic screen cover between the tower legs...that's it.
    • psuchaz
      • Jun 2017
      • 4
      • NV
      Thank you very much
