Going from forward to reverse??
  • Joeylabau
    • Jun 2017
    • 85
    • Goodyear AZ
    • 16 G23
    I have a g23, I wanted to get some advice on dropping from forward to reverse. Is this ok???
  • wakerider107
    • 271
    • south
    You mean going from forward to reverse and not stopping in neutral first? Its like going from drive to reverse in your car - not good for the transmission.
    2012 SANTE 230
    • charlesml3
      • Jan 2008
      • 2454
      • Lake Gaston, NC
      • 2022 G23
      You can't go directly from Forward to Reverse. You have to hit Neutral in the middle. I'm not sure exactly what Joey is asking here.
      -Charles
      • wakerider107
        • 271
        • south
        -Charles
        If you hold the throttle lock up you definitely can go directly from forward to reverse - the transmission locks up and the boat will shut off.
        2012 SANTE 230
        • charlesml3
          • Jan 2008
          • 2454
          • Lake Gaston, NC
          • 2022 G23
          Are you talking about the lift switch just under the shift knob? All that does is keep you from kicking the boat into gear if you step off with the engine running. That's it. The transmission CANNOT go directly from Forward to Reverse.
          I don't know what you mean by "the transmission locks up and the boat will shut off." I've seen more than one inexperience driver panic and slam the boat into reverse to keep from hitting a dock. It isn't all that pleasant, but there's no lock up and shut off.
          • Guntersville230
            • Aug 2015
            • 419
            • Guntersville, AL
            • 2015 SAN 230
            Need a much better discription of what you are talking about. Are you
            1) slowing rocking back and forth between forward and reverse while idle to pick up a rider and "tightening up slack" in the ski line without pulling the rider/skier too hard?
            2) are you going from 20mph and SLAMMING the throttle from forward to reverse (NO idea why you would do this but it is an "option")
            these 2 things are very different and at very different RPMs....so give and example of what you are talking about and this may help to better give you an accurate answer......
            • lucky7t
              • Mar 2011
              • 1306
              • Oklahoma
              • 2015 SANTE
              I go forward to reverse alot while going to gas dock and such . Only at very slow speeds simply to maneuver
              Current Correct Craft Boat
              Correct Craft Boats Owned
              • GMLIII
                • May 2013
                • 2795
                The loa oulleuy[IMG]k. Oh lbkudoy[/IMG]
                • charlesml3
                  • Jan 2008
                  • 2454
                  • Lake Gaston, NC
                  • 2022 G23
                  There's no problem with this whatsoever.
                  -Charles
