Ok guys, so I've been searching around and I have a pretty good idea that I probably need to just replace the starboard keypad but just wanted to check and make sure there isn't something else I should be checking before I order a $400.00 part. Last time I had the boat out, I noticed that when I tried to turn on my ballast pump to empty the tanks that the light didn't come on. Next thing I notice is that switches I never touched are lit up, like the heater switch, which mine doesnt have that option. Now, if I connect, then disconnect the 4-pin at the back of the keypad, it will randomly light up the switches on the keypad. Sometimes all switches light up, sometimes just a random combination of about half light up. It seems replacing the keypad will be straightforward enough, but just wondering is there anything before the keypad that I need to be checking. TIA
Tags: None
Sounds like the keypad is probably bad.
https://www.nautiqueparts.com/produc...-in-black-now/
Use discount code PND for 10% off.I own and operate Silver Cove Marine, which is an inboard boat restoration, service, and sales facility located in Mooresville, North Carolina. We specializes in Nautiques and Correct Crafts, and also provide general service for Nautiques fifteen years old and older.
