Asco valve instllation help (ballast system)
  • yoimpuct
    • 14
    • JAPAN
    • 1984 SKI NAUTIQUE 2002 AIR NAUTIQUE 2004 SUPER AIR NAUTIQUE 2006 AIR210
    I have 04 Super-air in Japan.
    It has the problem in ballast system.(water leak)
    This bulletin board was seen, and the Asco 8210 Electric valve was bought.However, the manual is not detailed.The valve was not able to be opened in the test.
    How can it be opened?
    Is it the best to take wiring from which part of the pump?
    Please put the photos if it is possible.
    #I am not good at English.
    When the mistake is found in sentences, I'm sorry.
  • richard
    • Feb 2005
    • 406
    • HK
    RE: Asco valve instllation help (ballast system)
    To open the valve, you must input the correct voltage and enough current. Second ,do you get a low pressure ASCO, for electric valve,there are low and high presssure type valve, if you get for high pressure valve,may not open if there are no high pressure input ,
    • yoimpuct
      • 14
      • JAPAN
      Thanks for youe answer.
      My following valves were bought.
      8210G95 12/DC
      air int 40psi
      water 40psi
      11.6watt
      Whether my valve is a high pressure or a low pressure is not understood. It ties directly to 12v 105amp battery and it tests. It is not possible to open it yet.
      • richard
        • Feb 2005
        • 406
        • HK
        Asco valve
        40lb should be high presure valve, seems not suitalbe for ballast use, u heard any click sound or spark when connect to battery?
        • yoimpuct
          • 14
          • JAPAN
          Thanks for answer
          No reaction even if it connects it with the battery.
          It hears of neither the spark nor the sound.
          2 red lines and a green line has adhered.
          I connected 2 red line in + and a green line in -
            • 2908
            Connect one red to + the other red to - don't use green, valve should open.
            • richard
              • Feb 2005
              • 406
              • HK
              Asco valve
              Mikeski should right, you could open the valve?
              • yoimpuct
                • 14
                • JAPAN
                I was able to open the valve.
                Thanks.
                • yoimpuct
                  • 14
                  • JAPAN
                  The valve was installed.
                  It is very good. The problem of leak was solved.
                  Helm Control is unnecessary.
                  The adjustment of the wire is also unnecessary.
                  It is possible to control with the switch of the ballast pump.
                  • richard
                    • Feb 2005
                    • 406
                    • HK
                    Asco valve
                    yoimpuct: Congrat,You did a nice job, seems I need to upgrade my ballast system with solenoid valve,(my boat is 2001 SAN) dosn't apply any solenoid valve, your style my be good for my reference, my ballast system remove out already, I near the time to put it back,how is your system funtion w/solenoid valve? I like to hear and refer. the sketch is my original system.
                    • yoimpuct
                      • 14
                      • JAPAN
                      I like to make the independence of port and stbd.Right and left balance can be taken. The water supply time can be shortened.
                      • goodfoot00
                        • 39
                        • Noblesville, Indiana
                        I bought my solenoid valves at STC Valve.
                        http://www.stcvalve.com/I-Solenoid-spec-2W-2S.htm
                        They are much cheaper than Asco and have a higher CV rating. Nice guys too.
                        1995 Super Sport, GT40 with EFI
                        NDT Tower, plumbed ballast, PP
                        • yoimpuct
                          • 14
                          • JAPAN
                          How much is STC valve ?
                          Ascovalve is about $120.
                          • richard
                            • Feb 2005
                            • 406
                            • HK
                            electric valve price
                            I asked they sell $62,bronze,low pressure ,can't remember brand I will look at S.S.
