2015 G23 horn not working
  • dadof3
    • Jun 2017
    • 25
    • Garfield AR
    • 2020 G23 2015 G23 2013 Malibu 247 2006 Malibu VLX 2001 Malibu LSV
    Any ideas on what I could do to fix it? Nothing happens when I push the horn button.
  • Kporsch
    • May 2013
    • 121
    • Houston
    • 2018 G23
    Probably needs replaced. They are known to go bad. Easy to replace though. Disconnect the wires at the horn. Put a voltmeter on the wires at the horn end and have someone press the horn button. If you see 12v at the wires then you have a bad horn.
    • dadof3
      • Jun 2017
      • 25
      • Garfield AR
      I haven't had this boat long....what's the best way to remove the panel and gain access to the button?
      • charlesml3
        • Jan 2008
        • 2454
        • Lake Gaston, NC
        • 2022 G23
        It's held in by those standard "Christmas Tree" studs. Usually you can pull the panel and replace it a couple of times before the studs either break or wear out.
        -Charles
        • dadof3
          • Jun 2017
          • 25
          • Garfield AR
          Great, thanks. Oh, one more question....do you know where I can get another horn if that's what's wrong with it. It would be a warranty item, but honestly the hassle of driving the boat to the dealer 2 hours away may not be worth it.
          • GMLIII
            • May 2013
            • 2797
            Try www.nautiqueparts.com . They can get you a horn.
            • thedude
              • Apr 2007
              • 451
              • SW PA
              On the 2013 G23, the horn is near the amps, with its own thru-hull fitting. You can crawl in there and easily remove it. $45 from nautiqueparts. I'm guessing your 2015 is the same. Just slide the horn piece out from the mounting bracket. Install new horn in its place. No tools needed.
              • charlesml3
                • Jan 2008
                • 2454
                • Lake Gaston, NC
                • 2022 G23
                Call your dealer. If they feel good about you doing this DIY, they'll just ship you the part.
                -Charles
                • dadof3
                  • Jun 2017
                  • 25
                  • Garfield AR
                  Thanks everyone.
                  Here's the part, fyi....
                  https://www.nautiqueparts.com/produc...aphragm-style/
                  • Rhodes2nowhere
                    • Jun 2020
                    • 46
                    • Birmingham
                    • G23
                    Is the horn super low volume wise?
