Oil Extraction Pump Tubing Broke off in Dipstick Tube! Now what?o
  • Evening Shade
    • Apr 2015
    • 1295
    Just turned 25 hours on my new boat so it's time for the first service. I was going to take it to the dealer, but they are backed up 4 weeks so I decided to do it myself. Now wish I wouldn't have even attempted it.
    I have a Topsider oil extractor that I have used several time in the past. I inserted the tubing in the dipstick tube and advanced it easily. I realized that I probably advanced the tubing in too far into the oil pan, but when I tried to pull back on it it wouldn't budge! I tried pulling a little harder with steady tension and the tubing broke off in the dipstick tube. Any ideas on what it could be hung up on? Of course I'm freaking out now fearing the worst.
    I have a friend who owns a boat shop locally (not a Nautique dealer). I took the boat to them so they could see if they could get the tubing out of the oil pan and dipstick tube.
    Anyone have any ideas on what else I could do if they can take care of it at my friends boat shop?
  • Blamey
    • Sep 2015
    • 595
    • New York
    Do a search but I've heard it happens. Unfortunately i believe you need to pull and open up the transmission.
    • Blamey
      • Sep 2015
      • 595
      • New York
      Also,it's suggest to use 1/4 inch copper tubing to prevent this. Too late now but may help in the future.
      • Aebert2668
        • Oct 2014
        • 49
        • Atlanta
        • 2006 SAN 220 2006 18' Hewes Redfisher 1979 16' Duracraft
        It's a long shot but I would try medium gauge fishing wire with an ever so slight angle at the tip. Then go fishing, so sorry this happened to you.
          • 16548
          Instead of trying to pump it out through the dipstick tube, use the oil drain hose that's already attached to the oil pan. You will need an adapter on your pump to connect to the end of this hose, but it will keep stuff like this from happening in the future, and it will let you get pretty much all of the oil out, unlike going through the dipstick.
          • charlesml3
            • Jan 2008
            • 2454
            • Lake Gaston, NC
            • 2022 G23
            I don't even use an adapter. I just thread the extractor tube into oil drain hose. I get it far enough in where I figure it's at the lowest point and draw the oil out from there.
            -Charles
            • Evening Shade
              • Apr 2015
              • 1295
              Its in the engine not the transmission.
              • Aebert2668
                • Oct 2014
                • 49
                • Atlanta
                Many GM engines have a pressed, removable dipstick tube, seated with two rubber gaskets and a bolt to the engine. See 1Aauto 2000-2006 Tahoe dipstick tube removal. I'd call PCM and see which Chevy block they used and if it has a removable dipstick tube. Maybe try the oil extractor from the top of the tube, extreme suction may pull it to the top.
                • Blamey
                  • Sep 2015
                  • 595
                  • New York
                  I see that now.
                  • scottb7
                    • Aug 2011
                    • 2198
                    • Carson City, Nevada
                    yeah, I agree with above...you gotta find out how the dipstick tube is connected to the oil pan...Yeah, and next time don't shove stuff down there...I agree with jeff, adapter from end of oil extractor to your pump.
                    • Evening Shade
                      • Apr 2015
                      • 1295
                      I was hoping that I wouldn't need the pump at all. With my old Malibu I could just drop the drain hose through plug hole in the bottom of the boat and it would drain by gravity, but the hose is too short to reach the drain hole in my GS20.
                      Do you know where I can get the adapter to fit on the drain hose?
                      • Evening Shade
                        • Apr 2015
                        • 1295
                        The dipstick tube is just pressed in and sealed with a sealer. My friend that owns the boat dealership is going to have his mechanic remove the dipstick tube and hopefully get the tubing out, but my fear is that it is hung on something in the oil pan. Fingers crossed.
                        I would like to take it to the Nautique dealer, but they are an hour away and are backed up 4 weeks in the service department, plus it's supposed to rain all week.
                        • core-rider
                          • Feb 2004
                          • 1350
                          • Huntsville, AL
                          • 2003 Black SANTE
                          My guess is you had the engine warmed up before trying to change the oil correct? I almost had your same issue a few years ago when I ran the boat on the river and then changed the oil at the marina... The plastic tube began to melt in the dipstick tube. I got lucky and it came out, but it was questionable for a minute. I've began using the drain tube and connecting the suction pump to it from now on.
                          Point is... It may not be stuck on anything inside the engine but melted and stuck inside the dipstick tube. Hopefully they can get you taken care of with minimal effort and back on the water.
                          Jason
                          All black 2003 SANTE
                          -- Southern Fried --
                          • scottb7
                            • Aug 2011
                            • 2198
                            This is what you need...notice i said "need" not "want"...This works and not fancy...Take off plug from remote drain hose, screw into bushing...Bushing attaches to adapter, and adapter attaches to drain pump...Works perfectly.
                            Get over your fancy pants stuff...warm up oil somewhat and works like a charm.
                            Click image for larger version  Name:	oil change pump.jpg Views:	1 Size:	92.3 KB ID:	525959Click image for larger version  Name:	oil change fittings.jpg Views:	1 Size:	144.1 KB ID:	525960
                            • charlesml3
                              • Jan 2008
                              • 2454
                              • Lake Gaston, NC
                              • 2022 G23
                              You don't need an adapter. Simply take the brass cap off and thread your oil changer tube into the drain hose. I did this for 17 years on my 99 Air and once now on my 230.
                              -Charles
