2004 sante 210 ballast valve
  • Chris5084
    • Sep 2016
    • 150
    • Arkansas
    Are these aftermarket valves? These are connected to open and close levers in my engine compartment. The ballasts are still filling when they are closed. Just trying to figure out what's been done.
  • charlesml3
    • Jan 2008
    • 2455
    • Lake Gaston, NC
    • 2022 G23
    I'm fairly sure those are aftermarket valves. That rod attached to the valve top there should let you close it. Does it turn? It should 90 degrees.
    -Charles
    • Chris5084
      • Sep 2016
      • 150
      • Arkansas
      Gotcha. It does turn 90 degrees and shuts it off. Once the boat is in motion, the ballast will fill up. Even with it shut.
      • functionoverfashion
        • Jun 2017
        • 509
        • New Hampshire
        • 2003 SANTE
        Are you sure those go to the ballast? Just asking because I see people put valves like that inline with a heater hose sometimes so the heater can be shut off or more easily drained - it looks like that valve has a little drain on it. Just a thought.
        • charlesml3
          • Jan 2008
          • 2455
          • Lake Gaston, NC
          • 2022 G23
          Then this isn't the ballast valve. It's something else.
          • Chris5084
            • Sep 2016
            • 150
            • Arkansas
            [QUOTE=functionoverfashion;525974]Are you sure those go to the ballast? Just asking because I see people put valves like that inline with a heater hose sometimes so the heater can be shut off or more easily drained - it looks like that valve has a little drain on it. Just a thought.[/
            No heater on this boat. I wish!
            • Chris5084
              • Sep 2016
              • 150
              • Arkansas
              Hmmm. When I have the lever in the closed position and I'm stationary they won't fill. Even when I turn the ballast pump on. I'm at a loss.
              • bowvan
                • Aug 2005
                • 100
                • sacramento
                Those are the original valves for your ballast, however those aren't the Flowright valves that usually fail and need to be replaced. The valves with the T handle are your manual shut off valves, to be used in an emergency or when your flowright valves fail.
                The valves that that get replaced are down stream of the brass valves shown in your picture. I don't remember if they are before or after the fill pump, but they are black and red plastic valves with a cable attached to them.
                • wakejunky
                  • 679
                  • Ca
                  • 2003 SAN
                  Those are ball valves and if they are close they should not let water through. If you say they do turn then I would venture to guess the top really isn't turning the internal ball valve or it's stripped out.
                  • XBIGPUN66
                    • Oct 2012
                    • 456
                    • WI
                    We had a 2004 sante. We just would manually open and close the ball valves and just left the flowrite valves alone. They did not work very well. We would open the ball valves, fill, then shut ball valves. Problem solved
                    Sent from my SAMSUNG-SM-G930A using Tapatalk
                    Ian S
                    2014 SANTE. NSS. Pro balllast. Boatmate trailer
                    2004 SANTE. 4000 lb ballast, 2013 graphics (prev). Ramlin trailer
                    2009 Moomba Outback (prev). Boatmate trailer
                      • Jun 2017
                      • 509
                      • New Hampshire
                      • 2003 SANTE
                      Since I looked at an '03 sante last night, I learned about these valves firsthand. This is absolutely the case, they're manual shut-offs as others have said. On the one I looked at, there was even an explanatory sticker on the aluminum frame right next to the handles.
                      Just confirming that others here are correct; I was wrong in my earlier speculation.
                      • Chris5084
                        • Sep 2016
                        • 150
                        • Arkansas
                        Apparently my flow rite control valves have been taken out. I have looked all over for it (the knobs to adjust). The only way I have to open the ballast is through the ball valves (manual shut offs). Tightened the nuts on the ball valves and 90% solved the issue. Thanks!
                        • Chris5084
                          • Sep 2016
                          • 150
                          • Arkansas
                          Here is where they are supposed to be! I think.
                          • Beach-TJ
                            • Oct 2010
                            • 207
                            • Lake Lanier, Ga
                            • 2004 SAN 210 TE
                            This is what they look like.
                            • bowvan
                              • Aug 2005
                              • 100
                              • sacramento
                              Helm Controlled ballast valves may have been an option in '03.
