Fake-A-Lake?
  • Evening Shade
    • Apr 2015
    • 1295
    Fake-A-Lake?
    I have a Moeller Fake-A-Lake. I tried using it for the first time the other day. I was a little concerned that the plunger didn't seat flush against the hull because the brass water intake fitting is so large. I turned the water on and started the engine. Water started coming out of the prop shaft as it should, but after about 30 seconds there still was no water coming out of the exhaust. I was afraid that the engine wasn't getting water so I turned the engine off. Is this normal? Does it take a while for water to start coming out of the exhaust?
    I'm interested in hearing what others are using to run their boats in the drive way? Is there a fake a lake with a larger plunger that will fit completely over the water intake so the plunger can seat flat against the hull?
  • surroundsound64
    • Jul 2005
    • 2147
    • Longview, TX
    • 2018 230 1981 Ski Nautique
    I don't know that I've ever seen a perfect fit with the fake-a-lake, mainly you just want to have a little reservoir for the engine to suck water in. It shouldn't take too long to get circulating... wondering if maybe the t-stat wasn't open yet to let water in? I don't know how the new engines are regulating all of that.
    2018 SAN 230
    1981 Ski Nautique
    Sold - 2011 Sport 200V
    Sold - 2000 SAN
    • Evening Shade
      • Apr 2015
      • 1295
      I was wondering the same thing about the t-stat, but didn't want to risk anything if water wasn't getting to the engine. It was definitely getting plenty of water to the prop shaft seal though.
      • MLars
        • Jan 2017
        • 52
        • Central Mass
        • 2000 Sport Nautique 1997 Seadoo GTX
        I've read the fake a lake doesn't provide enough water because most hoses don't have enough pressure. I just stick the raw water inlet tube into a 5 gallon bucket and use that. Even with the hose filling the bucket with the engine at idle, it can't keep up with how much water the engine uses.
        2000 Sport Nautique - GT40, Origin Wake Tower, 2700lb Ballast System
        • Evening Shade
          • Apr 2015
          • 1295
          There's no way I would be able to get the raw water inlet hose to reach a 5 gallon bucket in my boat.
          • thtrog
            • Apr 2012
            • 112
            • Asheboro, NC
            • 2014 G23 450
            This is what I installed and comes with a quick disconnect for your water hose, also use it to winterize with antifreeze. You can buy parts and make something similar or cheaper, but the quality SS valve and bronze parts add up fast.
            http://www.quickflushvalve.com/how-it-works.html
            • nohlan_4
              • Jan 2016
              • 413
              • Canada
              • 2013 G23 450
              I have a large fake a lake for sale that works on 2017 G23's so it should work on your boat if your interested?
              • Evening Shade
                • Apr 2015
                • 1295
                Does the plunger on your large fake a lake fit completely over the brass intake fitting so the plunger can seat flush against the hull?
                • nohlan_4
                  • Jan 2016
                  • 413
                  • Canada
                  • 2013 G23 450
                  Yes it does. I bought it brand new but my 2013 G23 has the recalled intake scoop on it which they added on the older year G's to help more water get into the intake. Which makes my intake too large for it to fit. I test fit it on a 2017 G23 at the boat show I bought it at and it fits perfect if your interested. Brand new never been used.
                  http://www.kijiji.ca/v-view-details....equestSource=b
