engine trouble, fuel light on but tank is over half full
  • justy31
    • May 2015
    • 7
    • Huntington Beach, CA
    • 2005 air nautique 226 TE
    Just got my 2005 Air Nautique 226TE 50 hour service from a shop I normally don't take it to but they work on all models, launched for a test run andand am now having engine trouble. The boat idles fine but as soon as it is put under load (going to plane or towing boarders), it bogs and I have to let off the throttle. I just installed 2 new site 27 batteries (old ones were 24), and a fresh air exhaust system. I thought maybe the motor had to calibrate so after a few laps, it seemed to not be as bad, although I still notice a significant loss in performance, barely pulls a small wake boarder up. After about 2 hours on ad off cruising, the "low fuel" light stated blinking and the gauge reads zero. There is over half a tan of gas. not sure where to start. thanks for any suggestions.
  • vacooley
    • May 2017
    • 58
    • Allen, TX
    • 2017 SAN 230; 2004 Malibu 23 LSV (sold)
    Check fuel filter first.
    • wakejunky
      • 679
      • Ca
      • 2003 SAN
      Fuel, spark and air....Fuel is probably easiest to check, make sure filter is clean, check cap and rotor and then check spark.
      • vacooley
        • May 2017
        • 58
        • Allen, TX
        Make sure the FAE is not blocking exhaust in some way. The symptoms you describe can also be caused by restriction in exhaust.
        • justy31
          • May 2015
          • 7
          Update: Took the boat out, seems to run ok, still a little hesitant but continuously gives the low fuel warning on the digital gauge and the needle gauge. While running, the gauges then intermittently worked a few times (5-10 random times during the course of the day). interesting is the "Hours left" read out then started to decrease over about a minute until the low fuel warning came back on. I am thinking of replacing the in line filter as well as the low pressure fuel pump. Any comments/suggestions? Thank you.
          • kmarine
            • Jun 2017
            • 109
            • chicago
            • boss gt40
            you have corrosion on your fuel tank sending unit wire. clean contacts and you shoud be good. Otherwise you may need a sending unit. The gauge works on resistance. if replacing the sending unit it works better if the tank is not full.
            • justy31
              • May 2015
              • 7
              would that explain the hesitation/running intermittent running issues as well?
              • kmarine
                • Jun 2017
                • 109
                • chicago
                • boss gt40
                Did you replace your fuel filter yet? I replace mine every year dirt and water in fuel cause intermittent performance issues. especially if you purchase fuel with ethanol.
