Nautique 210 random "clunk" when starting
  • gundogg
    • May 2006
    • 91
    • Nor-Cal
    • On Order: 2018 G23 Current: 2006 SANTE
    2006 Nautique 210
    Does anyone have any thoughts as to why the boat would have a hard clunk when pushing the push button start? It will clunk on first push. Clunk on second push and start easily on the third. This cycle continued the 4 different times the boat was started that day. Annual service was done in April with impeller replacement and starter replacement as well. Boat ran great until this. Boat has never ran hot, cylinders have always pressure tested at spec. Thanks for any input.
  • charlesml3
    • Jan 2008
    • 2454
    • Lake Gaston, NC
    • 2022 G23
    Originally posted by gundogg View Post
    2006 Nautique 210
    When it "clunks" does it continue to turn over, or does the starter "stall" and you have to release the start button and press it again?
    -Charles
    • gundogg
      • May 2006
      • 91
      • Nor-Cal
      That sounds right. I was going to have someone run back up there to check on it. The boat is sitting on lift.
      • charlesml3
        • Jan 2008
        • 2454
        • Lake Gaston, NC
        • 2022 G23
        OK, if the starter stalls when it "clunks" then it's a bad spot on the flywheel. A tooth is worn or chipped. I had this same problem on a boat (not a Nautique) many years ago. This doesn't necessarily mean you have to replace the flywheel. A good mechanic can insert thin metal shims in between the starter and the bell housing to slightly change the angle of the starter pinion gear to the flywheel. This will often let the starter get past the bad spot.
        -Charles
        • gundogg
          • May 2006
          • 91
          • Nor-Cal
          Thanks for the feedback. I will try to get it in somewhere to have it checked out. Of course something happens in middle of summer when there are no shops with availability in this area. Try to be responsible during winter and get everything running perfectly. I wonder if they did not install the new starter quite right... who knows. I hope it is something minor.
          • vacooley
            • May 2017
            • 58
            • Allen, TX
            • 2017 SAN 230; 2004 Malibu 23 LSV (sold)
            Loose starter can act same and will eventually damage the flywheel. Could also be a bad starter bendix assembly.
            • gundogg
              • May 2006
              • 91
              • Nor-Cal
              It turned out to be a failing solenoid on the starter I am told. Should be up and running now.
