wildlife
  • wildlife
    • Jun 2017
    • 2
    • Alberta
    • 1997 air nautique
    wildlife
    Have a recently purchased 1997 air nautique and the below 1200 rpm light flickers on and off sometimes above the 1200 rpm, what the problem ?
    one other question if I want to change the impeller , where is it located
  • Quinner
    • 2246
    • Correct Crafts
    Impeller will be pulley driven and at the front of the motor, if your Air is a direct drive, front of the motor will be towards front of the boat, if a VDrive it will be towards the rear of the boat. Is it a VDrive light or the check engine light you are referring to??
    • Fgroce
      • Dec 2016
      • 179
      • Middle Georgia
      • 2002 Ski Nautique
      I wonder if the light they are looking at is for the low oil pressure at 1200 rpm in a v drive?
