hole behind PCM decal on exhaust manifold
  • Grindleusa
    • Jul 2017
    • 3
    • Portland Oregon
    • 2007 Nautique SV211
    Have a leak in the exhaust manifold behind the PCM decal. Decal came off on the driver side and looks like there is a manufactured hole int it and not sure what it is for.
    Is this a manufactured hole?
    Do I need to replace the manifold or reapply glue to the decal?
    what is the weep hole for, is this a sympton of a different problem?
    any insight would be appreciated for this new boat owner?
  • wakejunky
    • 679
    • Ca
    • 2003 SAN
    There shouldn't be any holes in the risers. I suspect it's rusted out. Is it leaking/
    • Fgroce
      • Dec 2016
      • 179
      • Middle Georgia
      • 2002 Ski Nautique
      If it is weeping, you could try JB weld on it to get you back in the water till you get a permanent repair.
      • sfjakey
        • May 2005
        • 208
        • SF Bay Area
        • 2015 230 ZR6
        that boat has been run in salt. replace your manifolds and risers before you end up replacing the engine.
        • Grindleusa
          • Jul 2017
          • 3
          • Portland Oregon
          thank you for the replies. sfjakey you are correct apparently this boat was purchased in the San Fran area and has a closed cooling loop for running in salt water. I am replacing the pair of intake manifolds and risers. apparently there are two soft plugs on each side and expect that the other 3 are close to going too.
