1983 SN 2001 Issue
  • Agrass
    • Jul 2017
    • 1
    • Camarillo, Ca
    • 1983 Ski Nautique 2001
    1983 SN 2001 Issue
    I am having an issue with my starter remaining engaged whether the key is in the ignition or out. I just replaced the engine and had it out on the lake. Was working perfectly with no issues with the starter. Half way through the day, the starter engaged and kept spinning. I thought it was the ignition switch or starter relay. Replaced both and the starter continues to run anytime the Perko switch is on. Wondering if it is the starter solenoid. The starter only has one cable going to it and it seems the issue may lie elsewhere. Does anyone have any ideas? Thank you!
  • Fgroce
    • Dec 2016
    • 179
    • Middle Georgia
    • 2002 Ski Nautique
    Yes it will probably be the starter solenoid, you can replace it and should be okay, if it did not burn up the starter spinning. Our boat had that problem a couple of times and we had the starter rebuilt. You may be able to take it off and clean it up to get you by the weekend.
