I finally got around to replacing all of the pump impellers this weekend to see if the would correct the issue of bringing on water while underway and it seems to have worked. However, my starboard pump is still lagging quite a bit behind the other pumps on both fill and empty. Has anyone else had a similar experience? Is it possible that the pump is just getting tired, even with a new impeller or is it more likely an electrical issue? Thanks for any feedback.
