Prop experts: In a pinch, could I use an ACME 1579 instead of a 1235 for a weekend?
  • charlesml3
    • Jan 2008
    • 2454
    • Lake Gaston, NC
    • 2022 G23
    Hey gang,
    Hypothetical question: I'm debating buying a spare 1235 for my 2017 SANTE 230. I do happen to have a 1579 here instead which is a bit different:
    1579
    DIAMETER 13.5"
    PITCH 14.25"
    CUP .105"
    SHAFT 1-1/8"" - Left
    1235
    DIAMETER 14.5"
    PITCH 14.25"
    CUP .105"
    So obviously the only difference is the 1579 is an inch smaller. So would it work? Could I get away with it for a weekend or so until I got my 1235 repaired?
    Thanks!
    -Charles
  • max 1.6
    • Oct 2014
    • 284
    • Canada
    • 2009 Nautique 230
    Depends on what you want to do!!
    Will the boat move : yes
    Will the boat surf: probably but it'll spin faster in rpm to move it to same speed.
    You have the risk it'll cavitate and cause some wash on heavy weighted boat.
    • Sailfun
      • Dec 2016
      • 131
      • Lake Norman NC
      • 2018 Nautique G23 2022 Robalo 226
      It will be fine as a spare. It's going to be like going down 2" in pitch if not a bit more.
      • bandit628
        • Sep 2016
        • 318
        • Southern Illinois
        • Current-2012 SANTE 210 Past Boats 2000 Mastercraft
        If you weight it heavy it will take forever to plane. I just came from using a 1579 on my 210. It was terrible at holeshot weighted down.
        Sent from my SAMSUNG-SGH-I337 using Tapatalk
        • charlesml3
          • Jan 2008
          • 2454
          • Lake Gaston, NC
          • 2022 G23
          Fair enough. That's pretty much what I was expecting. Not great, but it'll do until I can get a new 1235 or have mine repaired.
          Thanks everyone!
          -Charles
          • kmarine
            • Jun 2017
            • 109
            • chicago
            • boss gt40
            The difference is diameter not pitch. you may loose hole shot as you are holding less surface area, watch your rpm's make sure not to over rev engine. otherwise not that much different. you may have a little more torque. as the engine will accelerate faster with less load. the pitch is the same so your planning speed should be close.
            • Dave Rittiman
              • Apr 2013
              • 209
              • Nor Cal
              • 2009 Nautique 230 Sold 2016 Supra SE450
              I have a 1235 ACME Prop in perfect shape For Sale if interested it was my spare for my 230 don't let a bent prop ruin your weekend.
              Recently had it checked and serviced in perfect shape Prop Only Bag not included.
              Asking $ 350 shipped
              916 202 1422 txt
              . Click image for larger version
Name:	1235 Prop .jpg
