Battery?
  • fabio
    • Jul 2014
    • 34
    • California
    Battery?
    I have a 1997 Ski Nautique with Ford GT40. What would be a good battery for my engine?
    Just purchased a Interstate battery with 850 cc amps. Is that to low or to high of cc amps?
    Thanks in advance!
  • charlesml3
    • Jan 2008
    • 2454
    • Lake Gaston, NC
    • 2022 G23
    I used Interstates in my 1999 Air Nautique for the entire 17 years I owned it. They always did just fine.
    -Charles
    • fabio
      • Jul 2014
      • 34
      • California
      -Charles
      Thanks for the info. What I forgot to ask was about the Cold Cranking Amps, just purchased one with 850 CC. Just wondering if that's to low or to high of CC amps.
      Thanks again...
      • kmarine
        • Jun 2017
        • 109
        • chicago
        • boss gt40
        That is good, I have a gt40 but use a two battery system and installed a battery switch. If your boat sits allot I recommend trickle charger at least monthly. You may also get a battery tender type charger. AGM batteries have a higher reserve capacity but cost more. It depends on how you use your boat, what your stereo system draws and make sure not to try starting with a week battery as that computer is sensitive to voltage drops. Furthermore they are no longer available. I am working with some people in this forum to solve the issue, but waiting for confirmation if it is a reliable fix. make sure you have good tight connections.
        • fabio
          • Jul 2014
          • 34
          • California
          Thanks for the insight! I have also been reading that they are no long manufacturing ECM for Ford GT40. I'm also hoping for a solve for this issue!!!
          If you know or read about any solutions please advise.
          Thank you again.
          • kmarine
            • Jun 2017
            • 109
            • chicago
            • boss gt40
            you can can check out hope for GT 40 ECM and follow along on planetnautique.
