What is the easiest way to drain the tranny oil? Thanks
- Apr 2005
- 1407
- Discovery Bay, CA
- 2001 Super Air Nautique (Current) 1998 Ski Nautique (former) 1982 Ski Nautique (Current)
RE: changing tranny oil
They sell a little pump, either electric or hand crank. You stick the tube in through the fill spout and pump it out. BKH2001 Super Air
I've heard that pumping it out can be tricky and you can't get all the fluid out. Here is what I have been recommended:
-place a disposable oven pan in the bilge
-remove drain plug from bottom of trany
-suck fluid out of pan however you would like
-refill trany
I'll be trying this method shortly as I'm a few hours overdue on the change. Oh, this was recomended for a direct drive, not sure if a v-drive would be different.Jeff
2002 Air Nautique (DD)
GT-40
Thanks for all your feedback. What brand of fluid you guys using?
Jeff, I have an '02 Air but mine is tan, green, black.'18 SAN 210 Reef Blue/Admiral Blue Metal Flake
'12 SAN 210 TE Black/Masters Blue
'09 SAN 210 TE Black/Fury Red
'08 Air 216 TE
'02 Air 216
'98 Sport Nautique
'89 MC Prostar 190
