Water pump question 2003 SAN
  • jratliff
    • Sep 2015
    • 13
    • Rolla Missouri
    • 2003 SANTE 210
    I need some help guys, is there anybody that has a 2003 San that can look at their raw water pump and tell me how it is oriented? All I need to know is the cam screw up or down?
    I know I should have marked the pump before I pulled it out it's been a long week at work and I'm trying to head out for a week on the lake and I want to get this right before I leave. Thanks in advance
  • core-rider
    • 1350
    • Huntsville, AL
    • 2003 Black SANTE
    The red arrow is the bolt the pump pivots on... the green arrow is what I guess you're calling the cam bolt... the hole in the bracket is slotted for it to tighten the belt. The small square hole you see next to the red arrow will fit a 1/2" drive socket wrench so you can tension the belt while tightening the bolts.
    Jason
    All black 2003 SANTE
    -- Southern Fried --
    • jratliff
      • Sep 2015
      • 13
      • Rolla Missouri
      • 2003 SANTE 210
      There is a flat head screw right in the middle of the pump, I think it faces down, if you put your hand under the pump you should be able to feel it if I am correct.
      • jratliff
        • Sep 2015
        • 13
        • Rolla Missouri
        • 2003 SANTE 210
        This is what the screw looks like
        • core-rider
          • 1350
          • Huntsville, AL
          • 2003 Black SANTE
          Yes the screw is on the bottom when mounted.
          Jason
          • jratliff
            • Sep 2015
            • 13
            • Rolla Missouri
            • 2003 SANTE 210
            Awesome! Thank you so much brother! You have no idea how much I appreciate it.
            • core-rider
              • 1350
              • Huntsville, AL
              • 2003 Black SANTE
              No problem man... Now get that boat back together and enjoy it!
              Jason
              • jratliff
                • Sep 2015
                • 13
                • Rolla Missouri
                • 2003 SANTE 210
                Absolutely! I have 5 days of riding to get started on!
