Help finding identifying missing hardware
  • shouse
    • Jul 2015
    • 76
    • Fort Worth TX
    • 2000 Air Nautique
    Bringing the boat out of storage and I appear to be missing a few hardware pieces. Not sure if anyone can help, but worth a shot. It's a 2000 Air Nautique era.
    1. I'm missing the bolts that attach the bimini top. I believe these might be a black hand-screw type bolt. Not sure if this 3rd party specific or Nautique oem. Seems oem.
    2. There's 2 screws that tighten down the kick board under the drivers console on the left hand side closest to the walk-through. Both have washers that flush the screw. I have the washers, but not the screw.
    Need help in identifying size for replacement. Pictures would be great. Appreciate it if anyone could take a few minutes to get sizes and/or pictures of these.
    Thanks!
    Pete
  • functionoverfashion
    • Jun 2017
    • 509
    • New Hampshire
    • 2003 SANTE
    Not sure on the bimini as I'm sure mine is different - it uses pins only - but the screws are very likely #8 or #10 stainless pan head, the ones on my kick panel are maybe 2 1/2" long. With that, if you have a few loose screws on a workbench or something, try a few out to see what works, then go get the right stainless ones from a hardware store.
