No spark on 1987 Ski Nautique 351 PCM
  • big schmizz
    • May 2017
    • 3
    • Pittsburgh
    • 1987 ski nautique 2001 1995 ski nautique
    I have an issue with no spark on a 87 nautique. Changed the coil and the ballast resistor. Still no spark. What am I missing?
  • charlesml3
    • Jan 2008
    • 2460
    • Lake Gaston, NC
    • 2022 G23
    Is the coil getting power? Distributor cap and rotor in good condition? Plug wires good?
    • big schmizz
      • May 2017
      • 3
      • Pittsburgh
      How much power should be going into the coil. And should I check it from pole to pole or from power to ground. Is there a circuit breaker that powers the coil also?
      • charlesml3
        • Jan 2008
        • 2460
        • Lake Gaston, NC
        • 2022 G23
        12VDC. Right off the ignition circuit. The "circuit breaker" there is the ignition key.
        -Charles
