I'm anxious to know how it turns out!
can anyone verify that this fuel tank sender will fit my 86 nautique with PCM ford?
http://www.skidim.com/prodinfo.asp?number=5903325
That happens to be busted too, so while i am at it.....
About the fuel filter, i dont know where it is. I can see the F/W seperator but dont know anything about it (and cant find any info). I also dont know where the filter is
This filter should be replaced Every year.
Just to let you know if you have not taken it apart, it will be hard to unscrew. An oil filter removal tool works well. A clogged filter will cause both problems when the boat heats up.
Originally posted by cat1168About the fuel filter, i dont know where it is. I can see the F/W seperator but dont know anything about it (and cant find any info). I also dont know where the filter is
UPDATE
Well, Skidim sent my parts, excelent service. We went out to the boat yesterday evening, and took the old EI out and swapped in the new, correct part from Skidim. Much different setup. Much more complicated, but the instructions were good.
So, everyone that told me i had the wrong ignition was....
RIGHT!!!
The boat runs amazing now! We had to retime it, because the timing was way off, and the boat was missing left and right. Once timed, she idled down to 600 smoothly. We had to make some carburator adjustments, but once that was smoothed out everything was perfect again. The boat runs up to 4400 rpm (about 37 mph if our spedo is correct).
Now all i need to do is replace my starter relay when it comes. enough of this click,click,click.....
Thanks to everyone for their help. This website has changed the way i feel about the boat!!
Jon
RE: UPDATE
Jon, glad you've solved the problem. I would think that either your speedos are off, or you have the boat propped oddly. At 4400 rpms, I would expect 43 or 44 mph (assuming you don't have it loaded with a bunch of weight). BKH2001 Super Air
Re: RE: UPDATE
Originally posted by surroundsound64Awesome! I'm glad that worked for you!!!
BKH is right... check those speedos.
Several options:
-Buy or borrow a little hand held GPS
-Drive it through a slalom course, time it and do the math
-Drive beside a couple of other boats whose speedos you believe to be accurate.
-Don't worry about it. Just enjoy your boat.
BKH2001 Super Air
