Gt40 1999
  • Farmer Jamie
    • Jul 2017
    • 4
    • Scotland uk
    • 1999 ski nautique PCM FORD GT-40 Engine
    Gt40 1999
    have a problem with engine runs fine but when I stop engine won't re start unless disconnect plug to fuel pump turn it over it fires and stops I then reconnect plug engine starts and runs fine . Had an issue with engine hunting on idle but has now developed to this
  • Nautiquehunter
    • Jun 2008
    • 2080
    Is it carbureted of fuel injected
    • Farmer Jamie
      • Jul 2017
      • 4
      • Scotland uk
      Hi fuel injection
      also engine idles abut 900. Rpm strong smell of fuel but engine seems to run fine just got it running of hose in my shed
      any help with this would be great
      • t.franscioni
        • Jun 2014
        • 715
        • United States
        • 2002 SANTE
        Sounds like it's getting too much fuel. I'd check the fuel pressure on the rail or just go ahead and install a new fuel pressure regulator they are cheap enough and see if that helps.
        • rbalan
          • 328
          • Georgia
          • 2002 SANTE
          Might want to replace the filter as well.
          • Farmer Jamie
            • Jul 2017
            • 4
            • Scotland uk
            Yeh think your right ordering new fuel regulater also think I'll replace vacuum pipe coming out the top of it just in case it's perished.Does anyone know if there is a cold start sensor on gt 40 EFi? Will check filter cheers.
            • kmarine
              • Jun 2017
              • 109
              • chicago
              • boss gt40
              You may want to check fuel pump relays and connections I recommend dielectric grease on marine electrical connectors. I have replaced them along with fuel pumps on these engines with fuel cell. pretty common with the gt40.
              • Farmer Jamie
                • Jul 2017
                • 4
                • Scotland uk
                Will do thanks
