Propeller spins in neutral
  • jeclarke
    • Sep 2008
    • 57
    I have a model year 2001 ski nautique. I recently noticed that the prop spins even when the trans is in neutral. Is this normal?
  • Fgroce
    • Dec 2016
    • 179
    • Middle Georgia
    • 2002 Ski Nautique
    Jeclarke the spinning prop in neutral is called a dirty neutral. The first thing you can try is to change the transmission fluid. Make sure you pump out about 2 quarts. Fill it to the full line while in the lake. Run it a couple of weeks and change it again.
    • joechrom
      • May 2012
      • 43
      • Connecticut
      • 88 SN2001
      Hmm. I feel like an idiot. My sn2001 is the same way. I guess I need to change my transmission fluid too
      • jeclarke
        • Sep 2008
        • 57
        I don't think it's dirty fluid. This is my 9th season with the boat and i've only put 120 hours on it. 220 total on the boat. I change the fluid myself at the end of each season, with less than 20 hours on the oil. What else could it be? Perhaps it is normal.
        • rolleronariver
          • Feb 2017
          • 21
          • Rogers, AR
          • 92 Sport Nautique
          Definitely not normal but you can also have a clutch plate that is warped. There's some good threads on correct craft fan about this.
          • Nautiquehunter
            • Jun 2008
            • 2080
            My 89 has been doing it for years . To fix it means a tranny rebuild so I will wait until its worse.
            • charlesml3
              • Jan 2008
              • 2454
              • Lake Gaston, NC
              • 2022 G23
              It's perfectly normal for that year model. I had a 1999 Air Nautique and the prop would spin in neutral from the day I bought it new. There's nothing to worry about here.
              -Charles
              • Fgroce
                • Dec 2016
                • 179
                • Middle Georgia
                • 2002 Ski Nautique
                I would change the fluid, if you have neglected your transmission for too long and the plates are warped then it will still have a problem. But if it is not to bad then maybe you will get lucky. I have seen it happen before. Good luck.
