Centering steering wheel...
  • tlarocque
    • May 2015
    • 92
    • CA/WA
    • 2007 SN 206
    Tired the search function but didn't find anything. I have a 2006 SN 206. Boat is perfect but drives me nuts that the steering wheel is about 40 degrees off-center when the boat is going straight. Not being mechanically inclined, I'm wondering if there is an easy fix for this.
    Thanks.
    -TL
  • XBIGPUN66
    • Oct 2012
    • 456
    • WI
    There is an adjustment in the rudder for on center steering. Just be aware that the setting will guve different results at idle vs on plane. You could also consider indexing the steering wheel if the rudder is not straight with the steering wheel at center.
    Sent from my SAMSUNG-SM-G930A using Tapatalk
    Ian S
    • tlarocque
      • May 2015
      • 92
      • CA/WA
      • 2007 SN 206
      Thanks Ian. I am finding some info on other forums too. I will give it a go, doesn't seem to difficult.
      Where are you in WI? My mom grew up in Stevens Point and she and my stepdad still have a great lake home on the Chain O' Lakes in Waupacca. Love it back there.
      • charlesml3
        • Jan 2008
        • 2454
        • Lake Gaston, NC
        • 2022 G23
        No. I'm sorry to be blunt, but NO. The adjustment you're referring to back at the rudder is not for centering the steering wheel. It's for adjusting the rudder throw so it's the same left to right. Do NOT adjust that unless you really know what you're doing.
        To recenter your steering wheel, take the center cover off the wheel and remove the nylock nut. Pull the wheel off and put it back on where you want it.
        -Charles
        • Miljack
          • Dec 2004
          • 1616
          • Charlotte, NC
          • '08 230 TE ZR6
          Charles is right, most likely the rack/wheel moved a little when the steering cable was replaced, either remember or mark the wheel for straight ahead and then remove the nut and pull the wheel. The nut should a 3/4"
          2008 230 TE-ZR6
          • XBIGPUN66
            • Oct 2012
            • 456
            • WI
            I am in Madison
            Ian S
            • Tryathlete
              • Feb 2015
              • 217
              • Lake Villa, IL
              • 1996 Nautique Super Sport
              If you're going to do it right, do it all the way. First you need to make sure the rudder has equal travel left and right. My local dealer replaced my steering cable and didn't get that right. I wound up doing it myself. It's easy. Once you get that right, centering the steering wheel at the helm is also easy. Just pull it and center it with the rudder centered--best to do this on the water so you can get it centered. Then of course there's tuning the rudder with tabs to keep the wheel centered both at idle and under power.
              • dixxy
                • Apr 2015
                • 136
                • canada
                • 2019 GS22, previous boat 2005 SV211
                I had the same issue. ..and here's how to solve this. ...did this twice actually since i took the rudder out to redo the seal the second time. ..
                Look under your elm at the steering colum. ..you'll see 4 bolts...loosen those 4 bolts turn your steering where you want it to be, then re-tight the bolts. ..
                Idealy you want to do this on the water. .drive slowly so the boat is going straight. ..then stop and adjust.
                I was tempted to adjust the rudder as well. .but my dealer told me about this. ..and this works.
                Sent from my SM-G900W8 using PLT Nautique mobile app
                • srock
                  • Oct 2008
                  • 1068
                  My father would always say, "When your out of Point beer your out of Stevens Point".
