On the water with Vibration in my 2013 G23 - stock prop
  • awhitlock3
    • Mar 2015
    • 38
    • Oklahoma
    • '13 G23 '06 SAN TE
    On the lake right now , I have a major vibration from 16-25mph
    There is no vibration at full throttle, no vibration when in neutral and reave up the motor, and no vibration up to around 10-12mph
    Would this be a bent prop blade? Loose prop, I can feel under the water and it seems , ok.
    Again I am on the water right now. I haven't hit anything to cause this to be the case, yesterday it was fine....any suggestions?
    I plan on getting a new power prop anyway but wanted to make sure this was the problem.
  • awhitlock3
    • Mar 2015
    • 38
    • Oklahoma
    So I think I found the culprit:
    The screws holding this to the boat were loose and 1 out of 4 is stripped in there....
    Any easy suggestions for a fix?
    • Wake.BC
      • Jan 2016
      • 423
      • BC, Canada
      What happened to the bottom of your boat?
      I would say just replace the screws but it probably has to be aligned or something.
      • wiggy G23
        • Aug 2014
        • 17
        • Australia
        • 2013 G23 450 2015 G23 450
        There bolts they have nuts on inside very hard to get spanner under motor
        Sent from my SM-G950F using PLT Nautique mobile app
        • kmarine
          • Jun 2017
          • 109
          • chicago
          • boss gt40
          The big question is why are they loose? These are locking nuts. Did the prop torque tear through the hull, did it hit something at some time? did the bolt snap and the nut is broken off? you most likely will want to tighten the nuts so the polyurethane seal is not broken or remove entirely and re seal bolts and replace with a new set of bolts, nuts, and washers.
          • nyryan2001
            • Mar 2013
            • 1993
            • Lake Anna
            You also very likely still have a bent prop. They will vibrate in and out of different rpm.
            2019 G23 450
            2014 G23 550
            2013 G23 450
            2011 Malibu Wakesetter 247
            2007 Yamaha AR210
