OK, so I recently swapped the hard tanks for bags beside the engine compartment of my 03 SAN. I am not sure if that is related, but since then I have been blowing the same fuse over and over again. The fuse is labeled "unlock" and it apparently powers the back hatch locking mechanisms as well as everything on my dash. I have checked most of the wiring for wire or wet connections and haven't seen anything. Could this been the bad Faria gateway issue that people seem to have? I read through that thread but no one seemed to have a fuse problem, just dead gauges.
Any thoughts? Should I go through the trouble of prying the gateway open just to check? Or does it sound more like just a ground issue somewhere in the boat?
