1999 Flight Control Tower broke - common?
  • Joshua J Rowe
    • Jan 2017
    • 85
    • Columbus Ohio
    • 1999 Air Nautique GT-40
    Tower broke last night. I believe it happened on the drive home.
    A good welder might be able to fix this.
    Anyone had this happen? If so what did you do?
  • Joshua J Rowe
    • Jan 2017
    • 85
    • Columbus Ohio
    From what I see on here....this is common. Not surprised, this tower is flimsy. It does not withstand lateral force very well. Good example of poor or non existent engineering!
    I would rather not drill more holes in the boat for a new tower so I do believe I'll be fixing this issue myself.
    I have in mind a few potential permanent solutions for this issue. Once I get it figured out I'll share with the community.
    If this had broken while pulling up a rider we could have had a very bad day! Not cool.
    • wakejunky
      • 679
      • Ca
      • 2003 SAN
      Those towers were a little more flimsy than new models. If you're gonna go through the trouble of getting it welded, you might as well look into adding gussets to strengthen it up.
      • xlair
        • 694
        • Wisconsin
        I would probably just bite the bullet and invest in a new dimensions tower. The old tower was the first of its kind but hardly an engineering marvel
        2001 Pro Air Nautique
        • Joshua J Rowe
          • Jan 2017
          • 85
          • Columbus Ohio
          I agree 100%
          I think I have a solution to prevent these failures.
          I don't know if it breaks forum rules to ask this question....
          Would anyone who owns a boat with this tower be willing to spend $150-200 for a bolt on kit that would prevent this failure and stiffen up the tower?
          I need to talk to a manufacturer about what it would cost to produce these things, but I'm fairly confident it would end up in that price range.
          • xlair
            • 694
            • Wisconsin
            There really aren't many of these towers left. Almost have already broken and gotten replaced so I'm not sure it would be worth your time but sounds like a good idea for a fix.
            • Tryathlete
              • Feb 2015
              • 217
              • Lake Villa, IL
              • 1996 Nautique Super Sport
              Stress riser on a cheap aluminum casting right at the drilled hole. If I were going to fix it, I'd put a solid piece of aluminum bar stock and weld it in place of that casting.
              • AC*
                • Jul 2010
                • 8
                • NC
                • Current: 1999 Air Nautique Previous: 1986 SKI NAUT
                Joshua - where are you located? I just replaced my FCT1 with a NDT on my 99 AN. Send me a private message if interested. I know these are notorious for breaking, but mine hasn't... I just chose to upgrade the looks of the boat.
                • Clmsnflyj
                  • Oct 2016
                  • 54
                  • Clemson, South Carolina
                  • 1999 Pro Air Nautique
                  When I purchased my 1999 PAN the tower was broken in 3 of the 4 drilled holes. I paid a guy 50 bucks to weld up the holes and put a bead around the tubing. Seems to be strong and was an easy/cheap fix.
                  • Pitty
                    • Jun 2017
                    • 32
                    • Canada
                    • 2002 Super Air
                    Does a 2002 SAN, have the same tower?
                    Sent from my SAMSUNG-SM-N920A using PLT Nautique mobile app
                    • Joshua J Rowe
                      • Jan 2017
                      • 85
                      • Columbus Ohio
                      I thought about that as well.
                      I also thought I could cut it off at the weld and machine a new one from a fresh piece.
                      • Joshua J Rowe
                        • Jan 2017
                        • 85
                        • Columbus Ohio
                        Thats a good point.
                        • Joshua J Rowe
                          • Jan 2017
                          • 85
                          • Columbus Ohio
                          I decided to buy a welder and fix this myself. The guy I had weld it a few weeks ago did not do work I trust, and when I got home I found the other side had a fracture as well. Plus I need to make a repair on my riding mower so.....welding here I come.
                          Anyone know what type of aluminum these towers are made of? One of the last bits of information I am looking for is what type of filler rod will be best to make this repair.
                          • a0128
                            • Jan 2014
                            • 423
                            • Lake Oswego, OR US
                            Nope. 2002 has what is known as FCT1 Gen2.
                            Here is a link showing the evolution of the FCT.
                            https://www.planetnautique.com/vb5/f...control-towers
                            • Joshua J Rowe
                              • Jan 2017
                              • 85
                              • Columbus Ohio
                              Here is a video of how I ended up repairing my tower. I think it may have been progressively failing. I would bet there were fractures long before it finally gave out. For other folks with these towers I suggest you inspect them every so often to see if fractures are forming! Everything is welded now, and the tower feels much stronger.
                              https://www.youtube.com/watch?v=8PJZ...ature=youtu.be
