2014 SAN 210 porpoising when wakeboarding
  • SuperAirHokie
    • Apr 2015
    • 45
    • Lake Anna, VA
    • 2014 Super Air Nautique 210
    Having a problem with porpoising when I wakeboard. Riding with stock ballast full (on Pro setting). Primarily happens if only a driver in the boat. Slight to nominal chop will cause it.
    Anyone else have same experience? Recommendations?
  • charlesml3
    • Jan 2008
    • 2454
    • Lake Gaston, NC
    • 2022 G23
    Sounds like you have too much weight in the back.
    -Charles
    • jondavis08
      • May 2016
      • 369
      • Battle Creek, MI
      • 2014 SANTE 210 2003 SANTE 210-Sold
      Need bow weight. Either people or a sac/lead. On my 2014 210 I ordered a piggy back kit from wakemakers and a under the seat bow sac(500). I ride with it full but I also have 850s in place of the original pro ballast so in need all the bow weight. It's a real easy install
      • SuperAirHokie
        • Apr 2015
        • 45
        • Lake Anna, VA
        Thanks to you both. I will start with more weightt in the front and then upgrade ballast.
        Jon - I think I just delinquently responded to you on another chain. I have not been on here in a while. Nautique was familiar with the issue.
        • lucky7t
          • Mar 2011
          • 1306
          • Oklahoma
          • 2015 SANTE
          Let out a little in rear . You will hardly notice the wake change
          Current Correct Craft Boat
          Correct Craft Boats Owned
          • swatguy
            • 1631
            • Midwest/ Northern IL
            • 2008 SANTE 210
            Two options , let little out of the rear, or add more to the bow.
            I cote option 2. Add more to the bow. 350 is a good start
            • SuperAirHokie
              • Apr 2015
              • 45
              • Lake Anna, VA
              Thx Lucky & Swat. Going to look into ballast upgrade all around.
