Originally posted by charlesml3
View Post
Originally posted by NautiqueJeff View PostFirst, be sure you have the Surf Select option on your boat. If you do not, you will not be able to pair the Pebble Watch.
If you do, you will need to pair the watch to the LINC system. Be sure to unpair it from your phone first.
See these guides for more information.
http://www.planetnautique.com/Correc...ringPebble.pdf
http://www.planetnautique.com/Correc...tInterface.pdf
Also, if your Pebble Watch is running an OS newer than 2.9.1, you will need to downgrade the OS before Surf Select will work. See this guide for more information.
http://www.planetnautique.com/Correc...eDowngrade.pdf
Originally posted by Lutfalah View PostI bought the classic. In the first wear, wtar got in and got messed up. I bought a steel which i had to return cause didnt work. Which would be the best? I just want to use it behind the boat all the time.
Thank you
-Charles
Originally posted by kdonzi123 View PostYes can only pause the music , i can not change tracks as well. Not a real big deal.Wondering though can you have multiple watches linked at the same time?
- May 2013
- 2795
- Smith Mountain Lake, VA (Craddock Creek area)
- 2017 G23 Coastal Edition H6 | 2001 Sport Nautique | 1981 Ski Nautique
Originally posted by Klipper View PostIs anybody else able to change tracks with the watch?
Sent from my Pixel 3 XL using Tapatalk
Yes I use the track changing feature all the time on the watch while surfing. As Charles stated above, this feature only works if the music is coming through a bluetooth signal. The feature will not work if the music is coming through an Aux cable.
Originally posted by Klipper View PostBluetooth does not work for me. Never has. I tried a few different classics and none of them work.
Your phone connects to the HEADUNIT via Bluetooth, USB or AUX cable. Even if you go through the LINC to pair your phone with the boat, your phone is NOT paired with the LINC. It's paired to the headunit. The LINC simply acts as a remote for the headunit.
If everything is paired up and connected, pressing the volume button on the Pebble sends that command to the LINC which then forwards it on to the headunit. It's no different than pressing the button on the LINC itself.
-Charles
OK, let's be clear on what we're talking about here. The Pebble watch communicates with the LINC via Bluetooth. That's the only way to connect the two.
-Charles
