G23 2017 Fuel gauge
  • Andy1972
    • Oct 2004
    • 128
    G23 2017 Fuel gauge
    Anybody out there experiencing an issue with the accuracy of the fuel gauge, my 2017 G23 says I'm at 0%. When I go to the pump, I'm only put in 50-55 gallons.
  • First226
    • Jul 2014
    • 31
    • Denver
    • 2005 226 TE
    I am sure that it goes to 0% early so that you have some in reserve in an emergency. I ran mine to 0% and put 57 gallons in, only 3 left. I would say that is basically 0%.
    • Andy1972
      • Oct 2004
      • 128
      Yeah 57 would be great, but sometimes I'm only able to put in 50, or less....in a 65 gallon tank.
      That's more than a 20% reserve?
      • markj
        • 1194
        • NorCal
        If you're underway, it usually reads like there's more in the tank. That's when it's most accurate. Standing still or idling is not accurate.
        • Kmayotte
          • Apr 2010
          • 819
          • Lake Winnipesaukee, NH
          I agree. It always reads more underway. It must be the shape of the tank or something.
          • charlesml3
            • Jan 2008
            • 2454
            • Lake Gaston, NC
            • 2022 G23
            My 2017 SAN 230 does the same thing. When we're underway it always reads higher. Sometimes it'll read 100% for the first couple of hours.
            -Charles
            • JoeA
              • Jun 2014
              • 808
              • Chickamauga Lake TN
              • 2015 G23 550
              I have a 2015 G23 and have ridden 20 minutes on 0% fuel at 25 MPH. This was not by choice but I am glad there is a nice reserve.
              2015 G23 550
              2013 Malibu 22MXZ
              • GMLIII
                • May 2013
                • 2797
                Good to know
                • swankster
                  • Aug 2010
                  • 1052
                  • DFW, TX
                  Took my 2013 G23 to zero last night and then put 55.5 gallons in it, so 9.5 in reserve.
                  2010 SANTE 230 343 (280hrs)
                  • wakemaker
                    • Aug 2010
                    • 237
                    its a good thing lo ran out of fuel in the 230 and it sucked needs a wr light
                    • xrichard
                      • Aug 2008
                      • 669
                      • El Dorado Hills
                      • 2023 G23
                      I've logged my fill ups to track this error. At rest on the water, my gauge reads conservative by 1-5% for the first half of the tank then 10-13% over the last half. If you track if for a bit, you can adjust in your head. For mine, I figure actual fuel is gauge +10% as the tank gets low.
                      Though the stated capacity is 65 gal, I don't know that the boat can actually use all 65 gal. It seems it would depend on the tank configuration and the running angle of the boat. So, at the end of the day, I just go by the gauge knowing I have +/- 6.5 gallons in reserve to account for the possibility that the last bit of fuel in the tank might not be available for use and as a bit of a buffer to run back to the dock.
                      (FWIW, the lowest gauge reading I've seen is 20%....it could be the error on my gauge increases below that point.)
                      Previous boats:
                      2015 G23
                      2008 SAN 210
                      2002 XStar
                      1995 Sport Nautique
