Installed PP stargazer this weekend on my 01 196. After a few cuss words snaking the servo wire I got it all hooks up and everything works flawlessly.
Only thing I noticed is prior to the install my volt meter gauge would read a solid 14v. With the PP now it reads between 11-12. With the blower on maybe a little lower. No issue starting the boat or running the accessories and the volt meter climbs when you are underway and higher rpm.
I've read about running thicker + & - wires to the dash but my electric knowledge is limited.
Any advice to determine how much draw there actually is and or how to run rectify the issue would be very much appreciated. Thanks!
Sent from my SM-G900W8 using PLT Nautique mobile app
