I replaced my impellar and can not reseal the water pump. The gasket didn't work so I used rtv silicone and it still leaks in the same spot. Any suggestions?
RE: water pump leaking!!!
It should seal with the gasket and a little RTV. You may have already done this, so bare with me....
1. Remove the entire pump from the boat and put it on the bench. I think some people change make the repairs without removing the pump but I only do that once in awhile.
2. Verify that you have all the old gasket removed. Sometimes it appears it's all off until you start scraping.
Good luck1976 Ski Nautique.....old but it\'s still going strong
My pump was leaking during the shake-down cruise this year too. Check your O-ring. Mine got out of the groove and was flattened. I had my old one still in the boat and replaced the bad one with that. Everything was fine after that.Once you have tasted flight, you will forever walk the earth with your eyes turned skyward. For it is there you have been and there you will long to return. - Leonardo De Vinci
Thanks for the replies. I did take the pump out twice and scraped everything clean.
PJ - when you say o-ring, do you mean the paper gasket?'18 SAN 210 Reef Blue/Admiral Blue Metal Flake
'12 SAN 210 TE Black/Masters Blue
'09 SAN 210 TE Black/Fury Red
'08 Air 216 TE
'02 Air 216
'98 Sport Nautique
'89 MC Prostar 190
I don't think mine has the rubber o ring. Maybe that is the problem. jDo all of the pumps use the o ring?'18 SAN 210 Reef Blue/Admiral Blue Metal Flake
'08 Air 216 TE
'02 Air 216
'98 Sport Nautique
'89 MC Prostar 190
Mine had no oring, just the paper gasket on the wear plate. Is it leaking from the wear/rear plate?? Maybe you have a blown seal on the shaft??
Check the wear plate edges and the pump housing edges for flatness too. You can take a stone over them to remove any burs, although there should not be any. You will see marks and a bit of grooving on the wear plate from the impeller spinning, check the edges around it. I put a light coating of silicone grease on the surfaces and them sandwiched the gasket.
RAW PUMP LEAKING
where leaking? A or B, I changed mine since B drop water during running. If A leak ,change O ring. If B leak, cheak other side assemble.I'm not confident fix B leak,so I change for have peace of mind. I order from DIM.
RE: O ring
My pump is different than yours but it is leaking at site A. I can sit it shoot out from the same spot no matter what I do.'18 SAN 210 Reef Blue/Admiral Blue Metal Flake
'08 Air 216 TE
'02 Air 216
'98 Sport Nautique
'89 MC Prostar 190
