2016 G23 450 HP Engine shuts down abruptly while surfing and the motor won't start
  • MuskokaG23
    • Aug 2017
    • 3
    • Toronto, ON
    • 2016 G23
    Has anyone come across a similar issue?
    I noticed in one thread a fellow had a lose connection on the key pad and experienced a similar problem.
    The only error log I found from 20 engine hours prior was - "DTC 2123: FPP1 voltage low" - is this the TPS sensor?
    Any thoughts?
    Thanks,
    John
  • OKWAKEBDR
    • 750
    • Lakefront
    • 2017 Super Air Nautique G23
    Perko switch probably came apart on the back side. There was a recall.
    Current: 2017 G23
    • MuskokaG23
      • Aug 2017
      • 3
      • Toronto, ON
      • 2016 G23
      Thanks for the info - I'm not familiar with the perks switch - what is it ?
      • OKWAKEBDR
        • 750
        • Lakefront
        The switch to turn on/off your battery or switch between the batteries.
        Current: 2017 G23
