My 1990 SN has (had) a 35 amp motorola alternator on it and it wasn't outputting enough amperage (half maybe)
this alternator has the regulator mounted on the rear of the unit.
so i took it to a local shop and he sold me on a new one (upgraded to 65A - internal regulator)
when i got it back, i hooked up the power wire and the wire that was in the connector (is this a field wire or voltage sense wire?)
now the boat won't shut off with the key or the ignition switch. (after pulling the alternator output wire the boat shut down)
The wire in the connector (field wire from above?) shows power when the key is in the RUN position.
seems the alternator guy is a little puzzled......
Comments??????
P.S. boat charges great! but this small run-forever issue is sort of important
Comments??????
