Want to make sure I put everything together correctly after changing the impellar. Should the screw and wording on the water pump be facing up or down on a 2003 Excalibur?
RE: Raw water pump installation?
I know this is too late for you, but may help someone else down the road. Before removing the raw water pump I marked "top" and "bottom" on it with a marker. After disconecting the hoses, I took it to my work bench and took a file ( or a hand grinder) and made a notch across where all three pieces ( the two outer halves and brass gasket) go together BEFORE taking it appart. I know this may sound anal, but trust me, I learned the hard way. Doing this sure does save alot of time lining everything back up when putting it back together. :idea:Tomfooter
\"You could by a cheaper boat, but then you would have to ride it.\"
