ok so i've been searching on here and so far i haven't had any luck, though i know ive seen it on here before. I'm pretty sure i'm having problems with my protec system, and i have the money to fix it so i figured i'd work on it now and hopefully catch another month or two of this season if i can get it fixed pretty fast. So I'm pretty sure I have the Ford motor in a 94 Sport but im clueless to what kits i need. I believe there were two kits to buy around 500 a piece if im not mistaken. Any one on here kind enough to point me to the right direction as to which kits to order so i can order them. And also how hard is it to make the conversion yourself from EFI to Carb. Do i need to be a mechanic or could i simply do the fix myself. i'm no mechanic by any means but i have common sense, and do repairs on a workover rig since im in the oilfield. could i handle this fix or should i pay someone to do it.
Here's the fuel system retrofit kit:
https://www.nautiqueparts.com/produc...protec-engine/
Here's the ProTec replacement kit:
https://www.nautiqueparts.com/produc...pcm-rk107025a/
