Unmapped SPN/FMI ?
  • Whitetail15
    • Apr 2010
    • 603
    • 2016 G23 H6
    Unmapped SPN/FMI ?
    Can anyone help with this warning code on 2016 G23 please. I got this engine diag code today on way back to dock.
    source: fuel sender
    engine hours 109.5
    plug 0
    SPN 731
    FMI 15
    count 1
    Description= Unmapped Spn/fmi
    everything seems fine, no issues
    2016 G23
  • a0128
    • Jan 2014
    • 423
    • Lake Oswego, OR US
    • 1999 Pro Air Nautique
    SPN 731 is related to Knock1 sensor. Unfortunately the Failure Mode Identifier (FMI) code (15) is not listed. Probably why the display shows unmapped spn/fmi.
    Likely the sensor is failing or you have picked some bad fuel.
    • Whitetail15
      • Apr 2010
      • 603
      • 2016 G23 H6
      should i just clear and see if it ever comes back or head to dealer?
      2016 G23
      • a0128
        • Jan 2014
        • 423
        Based on what you indicated - "no issues" - I'd clear it and see if it comes back. I'd would also contact your dealer, give them the codes and get their prognosis. Are you the original owner? If so, the warranty should cover any repairs.
        • Whitetail15
          • Apr 2010
          • 603
          • 2016 G23 H6
          thanks for the help
          2016 G23
