Can someone tell me what model/type works better with the surf select feature on the G23 2017. Thanks,
Tags: None
I just use the Pebble Classic. They're plenty cheap on eBay and work just fine. I believe one of the other models (maybe the Pebble Time) adds Ballast Shift to the watch, but that seems rather useless to me.
-Charles
I wish someone with a 2018 and Surf Select would confirm (or deny) that the Pebble works. So far, nobody has said anything.
-Charles
I have ordered a couple my self. I will do the same and comeback with the report. there is a lot of people complaining about the connectivity so i think we need to put it to rest. Either works as stated or its a complete flawed system Wait for an update!!
Originally posted by G_WaTT View Post
I ordered a classic off ebay. It should be in this week. If I get it before Thursday I'll report on connectivity, although I won't be able to test in water. I'll be on vaca the following week and away from my rig, but I'll be all over it as soon as I get back.
-Charles
I checked my LINC yesterday and it does give you the option to pair it with the pebble watch. I have ordered a couple and will try to sic them ASAP. I will keep you guys posted.
Originally posted by G23 GonZaga View PostI checked my LINC yesterday and it does give you the option to pair it with the pebble watch. I have ordered a couple and will try to sic them ASAP. I will keep you guys posted.
-Charles
Luckily I bought 2 because 1 ended up at the bottom of our lake. I think it came off when I was wakeboarding and crashed hard. So I have a second one and no more wakeboarding with it on.
2016 G23
I have a 17’ GS20 and they, Nautique, had to send me a 2.0 module as it was installed with a version 1. Unfortunately with Hurricane Harvey impact I havent been able to swap out and see if connects, I was near giving up until someone from Nautique rang me up ...
Installed new module his weekend that nautique sent me and my pebble time worked flawless. First boat and every instance of issue nautique has taken care of
Originally posted by mattkalin View Post
